1 - 9 of 9 Posts
rear weld center caps rattling????
Anyone have any problems with the center caps on there rear weld rims rattling? I just mounted a set of 26x11.5" -15 et streets on 15x8" 5.5b.s weld draglites and the rear center caps will not snug up tight with the wheels bolted up to the car. So ever time i drive it they rattle like crazy? they lugs are torqued to 90ftlbs and tightening them doesn't help. My skinny fronts don't suffer from this problem, yet the rear does. Is there any solution to this, like glueing them to the rim or does that not work? If it does what kind of glue should I use?
Thanks,
Kyle
Retired U.S. Air Force
I used duct tape around the lip.
Bending sounds better
Dave
isnt there a rule about the rear caps at the track? Is it just for hardened axles?
swervin said:
All you have to do is bend the outer lip of the centercap with a pair of pliers and problem solved.
The centercap rule is to check for aftermarket axles, but I don't think that most tracks do this for Mustangs.....
I bent a little "V" in my Centerline caps with a pair of side cuts, that cured it......
1 - 9 of 9 Posts
