Status
Not open for further replies.
Rear Sequential Turn Signals (STS) for '96-'97-'98 Mustangs. True plug-n-play installation. NO cutting, NO splicing of factory wires required.
$100 includes shipping to 48-states or best offer.
Just remove your original tail-lamp harnesses and install these modified Ford OE harnesses. Allows for a non-permanent modifiication so that the owner may revert back to factory operation. It doesn't get any easier. This kit will outlast the car.
Kit includes:
- Left hand rear Ford OE harness with built-in waterproof STS module.
- Right hand rear Ford OE harness with built-in waterproof STS module.
- Electrical load and timing calibrated STS flasher module (replaces the OE flasher located in under-dash fuse box)
Operation:
Turning: sequences the three bulbs of a housing once for each cycle of the turn signal. (as expected)
Braking: sequences the three bulbs of a housing only once for the initial application of the brakes. At the end of the sequence, all three brake lamps within the housing stay lit while the brakes are applied. From the factory, only two of the three tail lamps in a housing illuminate when the brakes are applied. With the STS installed, all three lamps illuminate giving a much brighter and more noticable braking indication to the observer.
Sequence style: (passenger lamp housing explained below)
This kit operates in this fashion:
OFF-OFF-OFF
ON -OFF-OFF
ON -ON -OFF
ON -ON -ON
OFF-OFF-OFF
Notice that the preceding lamps stay lit as the next lamp illuminates in the sequence.
Some other sequential turn signal kits operate this way:
OFF-OFF-OFF
ON-OFF-OFF
OFF-ON-OFF
OFF-OFF-ON
OFF-OFF-OFF
Notice how the lamps light up towards the right hand side but the preceding lamp goes out. This kit does NOT operate in this manner.
Came out of my '96 Cobra. Works perfectly.
$100 includes shipping to 48-states. (O.B.O.)
Discussion Starter · #2 · (Edited)
Sequential Turn Signal harness:
Image of Harness:
Click:
Taillamp Animation:
Click:
Discussion Starter · #5 ·
Sold and shipped.
Status
