New memeber looking for some advise and info. Looking to upgrade rear control arms or bushings. 1990 gt. Its a daily driver. A few mods done. Upper and lower intake. 70mm throttle body. CAI. Headers to full exhaust. 373 gears. Tires are 245/45/17. Rear lower oval bushings are worn out. Cant find stock replacements. Don't think I need to go tubular arms but would like some kind of upgrade. Quick search I found polyurethane bushings kits for stock arms. Waste of time? Whats my best value? Looking to replace rear springs also. Sagging a little in the rear. Should I go with variable rate or constant rate springs? Any suggestions would be great thanks
Funny how things come in waves.
Several years ago the factory style rubber replacement bushings were impossible to find.
About 3 years ago they were everywhere, and here we are again with them impossible to find.
My suggestion is to buy the poly bushings and swap them into the lowers, but go ahead and put fresh rubber ones in the uppers as well.
You said the uppers are still in good shape, but keep in mind that regardless of the lack of misuse, they are still 30 year old bushings.
Add that to the fact that when you install poly in the factory arms you are removing a load of compliance, which will all be transferred to the upper arms.
So don't cheap yourself into having to get back under there in a couple of months because the 30 year old bushings crapped out.
