1 - 9 of 9 Posts
Just got bought another Cobra and the first night I got it the driver side window started to die. It would only move in the middle of the range unless you helped it with your hand. Next day it quit completely. I figured it was the motor but today I pulled the motor and it ran fine off a twelve volt battery. Then I check the switch but that operated the pass side so its not that. I just checked the harness that the motor plugs into with a tester and there is no power. All the wiring behind the switches seems fine too. What gives?
Discussion Starter · #4 ·
94, Thanks a lot
Discussion Starter · #5 ·
I dont think that it has one touch down because there is no module between the switch assembly and the motor. The motor seems to work fine when I jump it off a 12 volt battery
Discussion Starter · #7 ·
Inside the door panel?
Discussion Starter · #8 ·
I am in idiot, I unplugged the module thinking it was part of the locking system. PLugged it back in and the motor works fine but when I put it in, the gear on the motor doesnt seem to be engaging the gear on the regulator, so the window just barely moves
Discussion Starter · #9 ·
Finallly just took it apart bushings are shattered, thanks for the help
1 - 9 of 9 Posts
