1 - 9 of 9 Posts
I had to move my steering rack forward to install new control arms and now I cannot slide the column back into the rack. Any help? I did align it and try to slide it over but would not move.This is as far as i can go before hitting the imprint.
it looks like you don't have it lined up, it will only go together in 1 spot. That cutout on the rack input shaft is for the bolt on the upper clamp to go through... hope this helps
you're out of phase by about 90 deg
I tried rotating the steering column to line up with that but it is impossible to slide over once it is lined up properly. I also loosened the steering rack again to make sure it wasn't due to uneven contact but still no luck
There's only 1 way it can go in. I've done this multiple times with 0 issues. You've done something wrong for it to be like this not able to be able to easily go back together.
If you find it impossible, I dont know what to say.......take it to a shop?
Are you trying to install it with the pinch bolt ??
1056942
This is what ive been doing for the past times. The indent is for the bolt?
spread the pinch with a screwdriver a little
then use some STRENGTH and PUSH the DAMN thing on!
I didnt know I had to pry it apart so much, I had a fear I would break it but it worked. I had the right idea I was just dumb lol. Thanks! Been stuck on this for a while.
1 - 9 of 9 Posts
