hey wildyellow,
do you get a click or pop when turning the wheel at slow speeds or when the car is stopped?
well here is my suspension stories.
got the car with 80,000 miles on it and at about 90,000 i started to here a click or pop when turning at slow speeds. i could not feel any ill effects from this. it became worse/more frequent so i took it to a shop. (i knew nothing about cars at this time). he listened and said it was a bad strut. so he replaced the struts and the brake pads without asking me
. the turning pop click was gone replaced with a bad clatter when going over bumps. the dumb sob did not put the anti rattle clips back in the calipers. after they were put in all clicks, rattles, and pops were fixed.
at 120,000 miles i had a real bad pop when turning that i could feel under my left foot near the dead pedal. this became worse and worse and would shudder the car when turning. took it to my buddies shop and he got under the car and felt the tie rod while i turned the wheel. this was the problem and i replaced the one tie rod. good as new!
