Is the ramp profile slow or quick? I was wondering does this make a difference in performance (torque, idle and HP).
hmm.. dunno
here are the specs from trick flow's site
TFS-51402000
Valve Setting Intake: .000 in.
Valve Setting Exhaust: .000 in.
Advertised Duration (Degrees): 275 intake/279 exhaust
Duration at .050 in. Lift (Degrees): 221 intake/225 exhaust
Camshaft Lift: .312 in. intake/.319 in. exhaust
Valve Lift with 1.6 Rocker Arms: .499 in. intake/.510 in. exhaust
Lobe Seperation (Degrees): 112
Intake Cam Timing at .050 in. Valve Lift:
Opens 3 degrees BTDC
Closes 38 degrees ABDC
Max lift: 108 degrees ATDC
Exhaust Cam Timing at .050 in. Valve Lift:
Opens 49 degrees BBDC
Closes 4 degrees BTDC
Max lift: 116 degrees BTDC
Firing Order: 1-3-7-2-6-5-4-8
Camshaft Notes: Good idle, strong midrange power. Aftermarket intake, heads, and headers recommended. Requires modified Mass Airflow sensor. Best with 9:1-10.5:1 compression ratio.
What does that mean? Get the mass air sensor recalibrated?
probably saying that the stock one can't handle the surging air coming through it because of the cam.
i dont know why they have that on there anyways since anyone who swaps cams probably already has all the bolt-ons..
Discussion Starter · #5 ·
I would like to know if they are refering to stock or afterrmarket also sense some of us on here experience surging problems after a cam swap.
i think they are referring to stock.. or they may be referring to the fact that if you swap heads and intake as they also reccomend, you should switch to bigger injectors which require a different mass air calibration.
TFS#1 appears to have a nice aggressive ramp rate. Advertised duration @ .006" is only 275/279 while dur @ .050" is 221/225. Not bad. This is comparable to some of the CompCam Xtreme lobes. Well, at least its alol closer in ramp rate to the Xtreme line than to FMS's ancient cams - LOL!
BTW - The TFS#1is a good cam for a 302ci/306ci IMHO.
