For Sale:
345 cubic inch SBF motor
R302 block
3.33 Sonny Bryant Billet crank
5.625" Carillo h-beam rods
4.060 arias pistons flat tops with valve reliefs for TW heads
11.2:1 compression ratio
TFS CNC'd Twisted edge 205's with a 64cc chamber, Heads have been milled .020
Edelbrock Super Victor EFI intake with fuel rails.
Cleveland Performance Center Custom Hydraulic Roller Cam
Canton Oil Pan and pickup
Comp Cams 1.6 roller rockers
Trick Flow rocker Girdle
This motor has a maximum of 5000 miles on it. This is an awesome street motor. Ive driven to and from the track it a few times(60 miles each way), ran a bunch of 10 second passes on motor, and it has run a best of 9.92 at 136mph on a 150 shot of nitrous. The motor has more in it on the juice, i have 3 full passes on the bottle.
$7500 obo
I also have a Liberty Faceplated TKO, and ram clutch and flywheel that can go with the motor for $1500 extra. If you would like this separate from the motor, the price is $2000. Buyer would also have a choice between an aluminum or steel flywheel.
The motor is still in the car, and still runs if anyone wants to hear it, and ill take serious local buyers out in the car if needed.
R302 block
$7500 obo
