I need to add some trans fluid to my AOD. I originally filled it with royal purple. Is it ok to top it off with a conventional ATF?
Most ARE compatable but, if you have a left over container of R P, it should tell you on the container.
Make sure you get the right stuff. Ford has changed a few times. Type A, F , Dexron II , III and Mercon V ?
