You can do that, BUT your 02 sensors will hit the crossmember and not bolt up correctly and hang like 3 inches off the ground. I broke both my rear 02s doing that. So I had to swap my 96 tranny rear housing on to the 99 Tremec tranny I had. Just swap the housings. I will make install a lot easier.Juiced46 said:ok sorry for the bad info (slaps self in the head). Well if the cobra nd GT dont line up right since he has a cobra he can just unbolt the crossmember and move and redrill the holes and mount it to where he wants. Right?
Your right.mysticcobradude said:just reopening to make sure that you just have to swap tailshafts in order to swap a gt t45 into a cobra, correct?
