1988 Ford Mustang Coupe
Midnight Blue (PPG Paint Code: MK)
25,000 Miles on Motor
$9000 obo or trade for a good Ford Truck
In Great Condition
Over $20,000 invested
Located In Belton, SC
Receipts for most modifications
MOTOR
DSS Pro Bullet 306 Block
Trick Flow Twisted Wedge Heads w/Competition Valve Job
Crane CompuCam 2031
Griffin Radiator
Trick Flow Street Intake
Motorsport 1.6 Roller Rockers
Pro-M 75mm Mass Air Meter
Cloyes Tru-Roller Timing Chain
Motorsport 65mm Throttle Body
NOS Purge Kit
NOS Dry Kit
NOS Braided Lines
Motorsport 30lb. Injectors
Motorsport Idle Adjustment Plate
C&L Inlet Tube
ALL ARP Bolts
ALL Fel-Pro Gaskets
March A/C Eliminator Bracket
Goodyear Silicon Hoses
BBK 255lph Fuel Pump
Crane Fuel Regulator
Mac H-Pipe
Flowmaster 2 Chamber Mufflers
Motorsport Hi-Flow Oil Pump
Crane Hydraulic Lifters
Competition Engineering Solid Motor Mounts
Crane Chrome Moly Pushrods
Trick Flow Valve Covers
160deg. Thermostat
Flex-a-lite Electric Dual Fans
Mac Underdrive Pulleys
Mac Shorty Headers
Billet EGR Eliminator Plate
ELECTRONICS
MSD Digital 6 Ignition Box
MSD Blaster 2 Coil
MSD 9mm Wires
MSD Coil Bracket
MSD Billet Distributor
Summit Battery Box
Summit Battery Disconnect Switch
Optima Dry Cell Battery (In Trunk)
Motorsport Hi-Torque Starter
SUSPENSION
Lakewood 70/30 Struts
Lakewood 50/50 Shocks
Mac Tubular Subframe Connectors
SouthSide Lift Bars
DRIVELINE
Tremec TKO Transmission
Motorsport Aluminum Driveshaft
Lakewood Driveshaft Loop
Pro 5.0 Shifter
McLeod Aluminum Flywheel
Aluminum Tremec Bellhousing
Ram 900 Series Clutch Assembly
BBK Clutch Quadrant
BBK Clutch Cable
Competition Engineering Solid Transmission Mount
Rebuilt 8.8 Rear End
Motorsport 3.73 Gears
EXTERIOR
Motorsport Cobra R 17x9 Wheels
Nitto 555 Extreme 245/45ZR17 Tires
Weld Lug Nuts
Clear Corner Markers
Cobra Grille Insert
Keenan 3" Cowl Hood
INTERIOR
Auto Meter Phantom Tachometer
Auto Meter Phantom Nitrous Gauge
Auto Meter Fuel Gauge
Auto Meter Oil Pressure Gauge
Auto Meter Water Temp Gauge
Auto Meter A-Pillar Pod
Auto Meter A/C Gauge Cage
White Face Gauges
Running Horse Floor Mats
'96 Seats
Tinted Windows
