On my friend's Mach 460 and 2 10" IMPP's, whenever you turn the stereo on, the subs "buzz" for about 3 seconds, remote off amp is hooked into fuse box, anybody know how to fix this problem? ~Brian
I am assuming that you mean that the remote turn on is hooked directly into the fuse box so that when the car is started (or in accessory) that the amp comes on, correct. This may be the cause of your noise, your amp is turning on before your stereo turns on. Check out these wiring diagrams , specifically page 130-4, 130-11 and the color code page. Note connection I (130-4) into the amp, this can be seen in the connector on 130-11 also. I believe this is the remote turn on for the Mach 460 amps, test this connection and make sure it powers up just after the stereo and you should be set.
DB on the drawing refers to Dark Blue.
Warning: Check everything first, make sure you know what you are doing, don't just trust me. Translation don't hold me responsible if it go Boom.
SN95GT50
