Can you put a wrench on the nut at the compressor blades and hold that side tight and remove the remove the bolt on the pulley? Cant seem to break the bolt loose. S/C is not on the car yet and I just got my RR ultra grip pulley and cant get the one that came with it off.
Get a pulley puller and use compressor/air and it will indeed come off.
Or if you put it on the car first you can do it. But thats more work!
Take it to any shop and have them hit it with an impact wrench. I really wouldn't put a lot of stress on the internal gears by holding the front bolt.
Once its on the car install the belt, put a 9/16s box end wrench on the bolt and whack the wrench with a hammer. Works every time.
When I put on the new pulley what color threadlock should I put on ???
