I want to know if you guys kept your heater hoses hooked up. If you did, how did you do it? (pictures, if you have them)
Another question is; What is the necessary mod you need to do to the throttle linkage to make it work with tall valve covers? Can you just get a 1 inch spacer to clear the vavle covers?
Thanks for the help,
Rick
On my 86 GT, I don't run the heater lines. Plugged one hole on the waterpump... everything else is routed as normal.
On another car, we ran rubber heater hoses instead of the stock metal ones. Looked like crap... but worked.
I removed cruise-control from my car and then cut that portion of the throttle linkage plate off... then everything fit just fine.
Later,
John.
PS- You might be able to see it in some of the pictures in the link below.
