The pivot point im using that was included w/ the bellhousing is too long, and is causing my clutch fork (Im using a fox HD one in my '95 BTW) to hit the front of the bellhousing, in turn messing up my clutch cable. Can I use the stock pivot point out of a T5's bellhousing? Any help would be appreciated....
Im using the aluminum Tremec belhousing.
I don't see why you couldn't use it. Whatever works!
That is the same one I am getting ready to use when I swap mine in. Sorry about butting in on your post but I would like to know as well.
FWIW, I can use my stock 94 fork in the bellhousing I have and the 87-93 fork seems to not fit out the square hole?? I bought the bell used BTW.
FWIW, I have the Tremec aluminum bellhousing in my car and it works fine.
I read on the other site that you burned up your cable correct? You might try using the stock cable and a firewall adjuster. That is the setup I have on mine and it works perfect. I'm also using a Fox style clutch fork.
