I just bought another emissions purge valve, the 1.5" round, about 3" tall. The top part has groves around the circle. I blew through it, and it slightly goes through just like my old one. I then put power/gnd to it as the service manual says to test it, and it doesn't change anything. No clicks. Did I get a new bad one??
Ok, I went to two dealers today and checked out some more of these solenoids. They all let a little air go through when blowing on one side of the ports (which the manual says should not happen). What you guys are calling the purge flow solenoid, is this it in the picture (egr vacuum regulator solenoid?)
You have it labeled correctly. Is the EGR vac regulator not the purge valve. The purge valve should be mounted off engine somewhere and have a green service cap on it.
