I am considering putting a Pure Street combination together using my signature parts with FoxLake stage 1 Lower Cobra Intake and stage 1 Holley cylinder head porting. Can anyone suggest what the best injector size would be to use on my combination, 24lbs, 30lbs? I would also be using a custom grind cam with a max. lift of .500.
Discussion Starter #2
I forgot to mention that this will be a 306 bored 4.030.
30lb injectors should work just fine. I'm currently running 42lb injectors because the 30's I was running were nearly maxed at 400rwhp and I decided to step up to the 42's since I was getting a new meter anyway. I'd go with the 30's for your combo.
