What all do I need to pull my motor? I know I need an engine hoist. Is there a specific lift plate for the 4.6?
Greg
CHAIN
just get a 4 lengths of chain if your pulling the trans too. I hooked two to the front acc and two to the trans to engine mounting bolts. Every one talks about how tight it is in there but mine came right out. One of those engine leveler bars helps greatly.
I pulled mine with the tranny - attached to the Bellhousing bolt mid way down , and the other to the Alt bolt.
Good Luck
Good Luck
Exactly what I did, came right out.
scott, it will come out with the LTs, you just need to be careful not to bang the brake stuff in the process. i went ahead and dropped the K-member to get mine out with LTs attached. went in really easy.
