What is the best way to get the engine out? Can i pull the engine and tranny easily or should i drop the tranny first?
i have been told that it is easiest to pull the engine and tranny as one whole
good luck
Just pulled mine saturday, leave the trans in, if you take take the radiator and fan out there is plenty of room. Just hook it up, pull the motor forward as far as you can and then up and out.
Another question... I bought this car and im pullin the engine to clean it up and replace soem worn parts. The engine has literally probably a quarter inch of grease\dirt\**** caked onto the block and a lot of other parts. Whats the best way to clean this off? Can chemical degreaser damage any of hte parts or am I safe dousing the whole engine with degreaser?
simple green works wonders
