Hi all,
1990 Mustang GT Hatchback:
I installed a Ford Racing Spring / Tokiko Shock/Strut kit 10 years ago, the ride height has always been low in the back and high in the front. It has C springs in the Front and B springs in the rear.
I cut a decent amount of weight by removing AC, Smog Pump, Fog Lights and Brace, using aluminum heads, fiberglass hood, 15 lb AGM battery. Maybe 150 lb total off the front.
I'm not sure if the weight reduction is playing a large part in the front end being high, or if the advertised 7/8" drop in the front and 1/2" in the rear was inaccurate, but I'd like to drop the front 1/2" or so and maybe raise the rear slightly to level the car.
Does anyone have a similar front-rear weight car with a set-up I can copy that rides well? I'm looking for a little better ride comfort than C/B springs as well, since I'd like to drive the car more than to and from a track and I'm not 18 anymore, my body is beat up enough.
Trying to figure out spring rates has led me to believe it's mostly marketing nonsense, and my experience with the previous set-up makes me concerned that the estimates are inaccurate, so I'm just looking to copy someone's setup that works well.
