gkscobra said:
I just ordered my p-1sc at my local shop and i asked about the maf so he made a phone call and they told him to run my stock maf, does this sound right?
I think you should check the body temp of the tech that told you that and make sure he is still alive.
#1 The stock MAF will be agonizing to get to idle properly.
#2 Even if you can get it to idle, it will peg way before you get to red line.
#3 That is way to much "fixing" for the ECU to do to make the MAF conversion work right with the big a55 injectors that you are going to need.
#4 Who is going to do the tune for your car cause he is going to get rich with all the time he will have to put into it to make it run right.
Trust the people who have been there and done that. Get the Univer now and save the headaches and wasted money. Or get it later
It's that simple, one way or the other you'll probably end up with the Univer.
