1 - 9 of 9 Posts
Procharger guys making over 500HP what size massair and type are you useing as a blow-throw?
How is it as a daily driver ?
From what I understand the stock Mass air meter tops out 400 rwhp, I believe the 90 mm would be adequate for the 500 rwhp mark
Discussion Starter · #5 ·
how is the drivability? I was told the Pro-M didnt idel that good.
Go with univer they are blow thru like you should have. one batch had an idleing problem but they are all good now.
Discussion Starter · #9 ·
ok thanks for your time guys
1 - 9 of 9 Posts
