Hey guys, i just bought a p1sc w/3core intercooler and a bullitt intake kit. i'm putting all of this on in about 3 weeks. I think I have all the parts I need for the install and i'm just looking for some insight on things i should or shouldn't do. I have:
42lb injectors
03 cobra fuel pump
90mm maf
jms chip
kennybell boostapump
i'm putting all of this on my 2001 Saleen vert. i've also had to purchase a new stock gt computer. jms chip supposedly will not work with the saleen powerflash. any advise or experiences would be greatly appreiated.
thanks,
al
sounds like you have the basics. If the procharger is a setup for the bullit then all should go well. Take your time with the intercooler and tubes they can be a pain to install if not fitted just right. And if the intake kit has all the many parts then it will be a simple bolt toghether job.
the procharger kit i bought was intended for the normal 2v intake. am i going to need to change out the valve covers to get the oil fill to the other side?
thanks,
al
01-891 Saleen vert
I didnt change my covers, just shorten the oil fill tube to sit flat on the cover. You will also need the air tube from the oval T boby to the cold air tube from the intercooler, its a cobra part from ATI.
