new user....probs with '86 stang
hey, i just built me a little stang. its an '86 notch lx 2.3 4-speed originally. i dropped in a semi-built 351W with a t-5 and 8.8 out of an '87 turbocoupe. now, the problem is, when i get about half way into my trottle, it starts vibrating really bad, but smooths out somewhat up top. could this be an unbalanced driveshaft? i'd appreciate help.
-zach
yah i am. is there a problem with compatibility with a 351W, 5.0 flywheel/clutch/p. plate, and turbocoupe t-5 tranny?
Super Moderator
Stop driving the car. The 351W requires 28 oz. balancer and flywheel/flexplate. The stock '83-'95 5.0L flywheels are 50 oz.. Get the correct flywheel before you make things worse.
i'm sorry, this is a little new to me. can you not balance a stock flywheel to make it work? can i change out the balance weight with a 28oz weight? if not, where is the cheapest place to get a new/used flywheel?
