1 - 1 of 1 Posts
i have a problem tuning the carb. im new at the whole carb thing so any advice would help. the car is set at 20 degree advance. i checked the plugs in the side and the fuel is at the correct level. i have the air mixture screws 3/4 to a full turn out. everything else is untouched from previous owner. the problem is when i rev it from idle it falls flat on its face then shoots fire out the top. could this be a timing problem or tuning problem. i havnt yet checked to see if number one is in the right spot but i will just thougt i would ask first thank you in advance
1 - 1 of 1 Posts
