I have 7 Probe forged pistons. This add is really only for someone looking for this exact piston. Bought a 347 that had one broken piston, and went another direction on the piston so I could run a small cc head.
Called Probe, these pistons aren't available anymore, and they would only make 4 new at a time for $500 because they are now a "custom" piston. Can't get just 1.
If anyone needs one, let me know! $75 each shipped to your door, or I can do a package deal if you need more than one. OBO
tech specs
Vendor Probe Industries
Product Type Pistons
Product Model Sportsman Race Series - SRS
Engine Displacement
331/347
Engine Family FORD - 302 Based V8
Material 2618-t61 Forged Aluminum
Base Bore
4.000
Stroke
3.250/3.400
Rod Length
5.400/5.315
Compression Height
1.175
Top Type Dome Top
Net Head Volume
+9.0
Dome Height
.110
Deck Thickness
.165
Dome Type Universal
Valve Pocket Cutters 2.150 Intake - 1.700 Exhaust
Valve Pocket Depth
.250 Intake - .200 Exhaust
Weight Without Pin
456
Wrist Pin Diameter
.912
Wrist Pin Length
2.500
Wrist Pin Weight
113
Pin Lock Type Double Spiral
Ring Set
CR1001
Top Ring Groove
1/16
Second Ring Groove
1/16
Oil Ring Groove
3.0
Top Ring Land
.275
Second Ring Land
.170
Bottom Ring Land
.090
Quantity Sold in sets of 8
Notes Will not fit Twisted Wedge cylinder heads
tech specs
Engine Displacement
331/347
Base Bore
4.000
Stroke
3.250/3.400
Rod Length
5.400/5.315
Compression Height
1.175
Top Type Dome Top
Net Head Volume
+9.0
Dome Height
.110
Deck Thickness
.165
Dome Type Universal
Valve Pocket Depth
Weight Without Pin
456
Wrist Pin Diameter
.912
Wrist Pin Length
2.500
Wrist Pin Weight
113
Ring Set
CR1001
Top Ring Groove
1/16
Second Ring Groove
1/16
Oil Ring Groove
3.0
Top Ring Land
.275
Second Ring Land
.170
Bottom Ring Land
.090
