This is a brand new install.
So I have a few plugs that I don't know what they are for. I do not have the factory plug and relay for the fuel pump. So I am not sure the best way to connect it. Chris suggested the Aeromotive pump wiring kit. I use to have the fuel pump, electrical water pump and fans all connected through relays and switches.
1076147
1076148
1st pic looks like oil pan level sensor, iat, cts. maybe the body harness that's on the ds corner of the engine bay. the second pic is for automatic transmission control. if you pull the sheathing back a bit it should say what its for. if it doesn't it will say pin number and then as Chris.
the aeromotive kit is beautiful but universal. you can build your own by following aeromotive wiring diagram.
Discussion Starter · #4 ·
Cool thanks I know one is for airbags as well. Whatever I don’t need plug wise I want to remove. I bought the awromotive kit ohh well
