I am using a hot rod harness for universal applications.
Two things that are disconcerting:
1. What's the deal with the small red/blue wire that goes to the starter relay? It was in the original factory harness but the Pro-M harness doesn't have it. Do I have to wire it up individually to the backup/neutral safety switch and to the TFI ignition module like it is in the original factory harness? And if so, how do I do this if my Pro-M distributor harness is a 94/95 style harness, and doesn't actually have a TFI module?
2. How am I supposed to set ignition timing with the spout out if the Pro-M harness doesn't even have a spout connector?
Looking for suggestions on how to proceed. Confused but willing to learn and admit my mistakes.
