Man, I hope I don't run into this issue with the DLG-1 as I really like only having one gauge to monitor both banks.
Do you know if there's an NGK alternate for the Bosch sensors that come with the Innovate system? I've replaced so many Bosch sensors on previous vehicles for the exact reasons you mentioned.A lot of the times the reason the sensor goes bad are a few things:
Sensor too close, they aren't nearly as durable as it's ngk counterpart
waiting for the sensor to hear up and pretending it's a glow plug,
and too many cycles while tuning the system.
Been there done that
Sorry I don't. You and I bought the system at two different times. During that time innovate started using a different wideband sensor. I think yours was Bosch 17065 where mine is 17012 or something like that.Do you know if there's an NGK alternate for the Bosch sensors jthat come with the Innovate system? I've replaced so many Bosch sensors on previous vehicles for the exact reasons you mentioned.
Looks good. It does take time to sort through everything.Spent some time getting the car running today. Had a few issues with keeping the car running and not throwing codes for being too rich, but after a discussion with Chris and adjusting the Low Slope on the injectors way down it finally runs. Still some issues that need to be sorted, but it runs a drives. Need to address the way oversize fuel pump I have and hopefully that will help with tuning the car and keeping the fuel temps down. Had an issue with the car shutting off on me twice when decelerating, not sure what that was all about, but I'll talk with Chris about it tomorrow. I like how the LS coils came out, they take up some room, but shouldn't have any spark issues again.
Oversized pump definitely isn't helping you. Stalling on deceleration is usually caused by improperly adjusted throttle blade. Try bringing up the idle pi correction into your variables. At idle it's supposed to be .010 or around there.Spent some time getting the car running today. Had a few issues with keeping the car running and not throwing codes for being too rich, but after a discussion with Chris and adjusting the Low Slope on the injectors way down it finally runs. Still some issues that need to be sorted, but it runs a drives. Need to address the way oversize fuel pump I have and hopefully that will help with tuning the car and keeping the fuel temps down. Had an issue with the car shutting off on me twice when decelerating, not sure what that was all about, but I'll talk with Chris about it tomorrow. I like how the LS coils came out, they take up some room, but shouldn't have any spark issues again.
Where is the idle pi correction located in the variables list? I'll drag that into my variables list tomorrow when i'm messing with the car.Oversized pump definitely isn't helping you. Stalling on deceleration is usually caused by improperly adjusted throttle blade. Try bringing up the idle pi correction into your variables. At idle it's supposed to be .010 or around there.
Two things you could change for stalling when decelerating. Your version of the software is newer than mine so some variables/wording may be different.Had an issue with the car shutting off on me twice when decelerating, not sure what that was all about, but I'll talk with Chris about it tomorrow.
You have two menus Calibration and Variables.Where is the idle pi correction located in the variables list?
I knew about those variables as I used them to tune my low slope. Just curious though, he mentioned, "Idle pi correction". Is that different?You have two menus Calibration and Variables.
Variables
Fuel
Closed loop
Bank1 UEGO
Bank1_UEGO_PI_Correction
You follow the same steps for Bank2 or you can watch the videos on page 1 of this thread.
I hope this helps
Michael Plummer
Found it, I'll check this today. Thanks.Idle pi correction is different from the b1 and b2 correction. It controls the correction between the throttle blade and bypass valve.
Go to variables-idle speed control-closed loop-idle_pi_correction
If it's off you will have to adjust the throttle blade in small increments. Watch the screen, make the adjustment and wait. The values don't change instantly. Make sure the vehicle is hot 195+, and make the adjustment when the fan isn't running.Found it, I'll check this today. Thanks.
Just got off the phone with Chris, there's a couple other things he recommended I try first, so I'll give these a try. I'll watch that idle pi to see it out of curiosity, though. Chris thinks that my big ass fuel pump is causing some issues and that I need to address that as well, I don't disagree at all.If it's off you will have to adjust the throttle blade in small increments. Watch the screen, make the adjustment and wait. The values don't change instantly. Make sure the vehicle is hot 195+, and make the adjustment when the fan isn't running.
You want it close to 0 but some correction is fine. Less than .015
Your running a mod motor, but you figures should be the same as mine. I would throw Chris Richards an email to double check.
Absolutely fix your fuel issue first. But the procedure I outlined will definitely help you with setting your idle.Just got off the phone with Chris, there's a couple other things he recommended I try first, so I'll give these a try. I'll watch that idle pi to see it out of curiosity, though. Chris thinks that my big ass fuel pump is causing some issues and that I need to address that as well, I don't disagree at all.
