Only reason I went with the DW injectors is because when I bought the system I was told by the sales guy that Chris had excellent data for them and he had actually helped DW with getting the correct data. Well after getting everything installed and talking to Chris he said that he did help DW with some injectors, just not the 88's that I have. So, I was a little pissed about that because I got rid of a good set of Deka 80's for these DW's.
The car is running decent, the MAF transfer should be perfect since Chris loaded it for the 3" Pro Tube. Chris admits that the 88lb data isn't totally correct that he supplied, but we'll keep messing with them until it's correct. The sensors are stock Ford Parts, although I think I'm going to replace the TPS since the mount holes have been drilled out for more adjustment and it makes it difficult to set correctly. Other then that, not much else needs to be tended to. Grounds are solid, charging system is great, no vacuum leaks, etc. I'm even starting to doubt any issues with the fuel pump. It might be bypassing a bunch of fuel when cruising or idling, but the fuel temps are normal and no pressure drops.
I do need to address the cooling system. In cooler weather the car won't stay above 180. Mod motor 4v cars came stock with an oddball thermostat housing with a bypass line to bypass the radiator until the thermostat opens. That bypass line has been removed and a standard thermostat housing has been installed on the outlet of the radiator. I'm going to move the thermostat to the inlet side of the radiator and get a new thermostat with no bypass holes in it. The one in there now has 3 3/16" holes in it, so it's bypassing too much coolant.
The car already runs better then it did, so even though it's not there 100%, I'm still happy with it.
