Ahh! I get you now.I'm just saying it might be the best compromise for someone who doesn't already have COP. That may be a better solution than dismantling a wire harness and trying to install COP wiring in a conventional harness like the OP said he was trying to do. It's because the crank trigger gives the ECU the best view of the engine position during operation. If you live in the state of CA and you have to use a distributor to pass a visual inspection at the emissions test station, you can still get the benefits of a better running car while still retaining the original look of the fox mustang engine bay. Sorry if I didn't make myself clear, BTW, I wouldn't want to go backwards myself. I pretty much hooked on the COP concept. I went through a lot of trouble to make it work on my own car. I'm in the process of installing a Ford 351W (460 cid, FRPP p/n M-6009-460) using the COP and the crank trigger. With COP and the crank trigger, I at least know that I will have a car that will measure up to modern day drivability standards.
I’m really excited to see how this plays out as more people move to the crank trigger. With a mod motor I had one from the factory, but I’m excited for you pushrod guys.
