This is not an "install post" but more of hey here is something to plan for if you are running an aftermarket pan.
A week ago I ordered the new crank trigger kit and it arrived the other day. Others have talked about the parts and quality and they are completely accurate.
I read the documentation that came with it several times. Install seemed pretty straight forward. I emailed Chris for the new calibration. Using the "compare calibrations" tool, I was able to update the new base calibration with my info.
This is where the fun begins. Please note Page 3 at the 2nd to last line "Intended for use with stamped steel oil pans. Aluminum pans will require modification to the mount bracket. Call tech support for details"
I am using a Moroso 20511 pan. It is steel so no problem. Ha Ha. Notice anything missing?
I will give you a hint. It rhymes with bolt hole.
I emailed chris and he suggested drilling a hole in the pan and using the bolt. That was my plan until i got into and saw there was more to it.
Also the way the pan is designed you can't just drill a hole. Lastly the pan to stud distance is to small for the bracket to fit on. So I get to modify the bracket. Please notice the ridge that the stud is on is part of the issue.
Here is the bracket so far: I have shaved some off the bottom
I am going to have to take more out on the right side. The pan itself is bigger and causes the top bolt to be out of alignment.
I know they can't make a bracket for every oil pan. I think they should change the documentation to read something about compatibility with "factory oil pans" only. I have a cheapo aftermarket pan also. It has the issues as this nice pan.
I think when i install my new motor i will see about making a new bracket that attaches to the first bolt on the side on the pan
I will update the process as it moves forward
