This has nothing to do with my post below but I just thought of it so I will ask.
I am putting in my own cold air kit. Looking at the stock air box, I noticed the plug going in to it. My question is, does pro-m make an adapter that goes from the maf to the plug that normally goes to the stock air box? The plug receptacle on the bullet and the plug from the harness look nothing alike.
Thanks Corral!
If I'm reading your post correctly, you are saying that the stock MAF electronic connector doesn't match up with the Pro-M. If this is the case, you more than likely have a MAF made for a different engine.
I'll try to post pics of what I'm talking about later.
Voodoo, I think you are asking about the wire that passes through the grommett. If so, just disconnect it from the harness, push the robber grommet out of the hole in the housing and pass the connecter throught the hole in the housing. I just leave the grommet on the wire in case I ever need to ptu the stock airbox back in.
