We've now set up a pre-packaged MS2 combo with a ready to run, premapped MS2 and adapter harness; check it out here:
http://www.diyautotune.com/catalog/...g-and-play-for-39863993-50-mustang-p-418.html
The base map will work in regular MS2 installations as well, as long as you're running the latest MS2/Extra release code, V2.1.0. We spent a good bit of time dialing in the closed loop idle for a relatively stock Mustang. A more heavily modified one (big cam or lightweight flywheel) may need some tweaking. People with existing MegaSquirts can get the map at this link:
http://www.diyautotune.com/megasquirtmaps/mustang-1993/1993-5.0-mustang.zip
