1 - 15 of 15 Posts
I'm just wondering what some of the stall converter sizes folks are running? I have a PI Stallion 3100 lockup and wondering if I've gone too high or too low?
Any opinions?
This is a weekend car only and I haven't even driven it with the automatic yet but anxiously awaiting some parts. So, I have no idea how it will shift and how the TC locks up, etc.
I have a 2800 Pi Stallion in mine. When I was n/a I could hook nice with Nitto Drag radials, but when I put the roots charger on it blows these Nittos off like nobodies bizness. If you are going to stay N/a I think you would want at least 3000 stall speed as a minimum.
Depends
That 3100 stall might stall at 3100 for your car, but it will change with power output. Like if it stalled at 3100 for a 250 rwhp car, it will stall somewhere like 3400-3500 for a car with 350 rwhp, etc. If I were you I would run it as-is. With PI, you get one free stall speed change anyways, so you might as well try it out. If you don't like it, you can always cash in on that stall speed change. Just remember to keep your receipt!
Discussion Starter · #6 ·
Sebastian said:
HP doesn't change stall speed...torque does. And it's 4R70W not R470W
I suggest drilling your seperator plate like suggested in Jerry's thesis in the technical articles on www.tccoa.com.
I run a 4K stall 9.5" converter.
Sebastian
Sebastian,
Thank you for the info, however, ..... do you think 3100 is good enough for me? I did not see a list of your mods so I have no idea what your combination is. Oops .. keep saying R470W when it's 4R70W :) My fault... < boink >
I would step up the stall a little bit. I have a blown 99GT motor with bullitt intake in my Thunderbird....keep in mind my car is a little heavier so it needed some more stall. I've never driven a blown auto stang. How does the car feel? Do you think it could use some more? You can always pay to lower the stall later ;-) I also have a special calibration in my EEC which gets rid of the mushy feeling on everyday driving.
Sebastian "Seabass"
Discussion Starter · #8 ·
Sebastian,
I have no idea how it drives to be honest. After blowing it up in February, I decided to change a lot of things and one of them was swapping from T-45 to 4RW70 tranny. Then the list kept on growing as I'm sure you understand ---- mods mods mods. Decided to ditch all the stock suspension and hopefully lose some weight off the heavy beast. So then the tubular k member, tubular a arms, coilovers, new shocks/struts. Then swapped rims (went from 17 x 9 cobra r's to Welds 3.5 skinnies / 26 x 11.5 ET streets). Unfortunately for me, I didn't have an engine then and could do all of that stuff. I now have a transplant to do (swapping to 2000 GT engine) and will see how it goes.
So I guess I can try out this 3100 stall and see what happens and if I like it or not. My fear is to have far too much stall and go down the beltway tacking too high. I have the trans-go shift kit on this tranny and the stall, that's it for now.
That's my story and I'm stickin to it :evil:
Bad:
I had a 2800 in my N/A 4.6L and dropped .4 in the 1/4 mile with it. I decided to put a 3200 in my new stang since they clearly like to rev a lot higher (better heads, cams, etc.) and I can tell you the difference was incredible. I'm not sure if you remember him but Paul99GT had a 2600 with his Vortec setup in his auto and said he couldn't get traction to save his life. Jim V. on the other hand runs the same stall as myself and has no problems with his 560+ HP combo car. I have heard, however; that if you get above 4200 then problems will start occuring so don't go too high. John Edwards is running a 4000 in his N/A auto and has been putting down some great times so I would say its all in what you want to do. IMO, being that I've had 2 converters with 2 different stall speeds, stick with what you have N/A and blown and you shouldn't have any problems. Just make sure you run slicks or some Nitto/BFG drag radials.
Also:
I noticed you said you have a TransGO installed, what year tranny is that? If it is a 99-02 GT auto tranny get a new valve body and save yourself a ton of hassle later on like myself and many, many others that fried theirs. The TransGO kits clearly have a problem on the newer style transmissions and cause either slight tranny failure or in my case, fried the entire thing. My car was down 2 months because of that stupid kit! I had one in my 96 GT installed by the same people and had 0 problems. Do some research on google, stangnet, and corral and you will see exacly what I am talking about. :mad:
Discussion Starter · #11 ·
rancid said:
Also:
Rancid,
The tranny is from 96-98 car :) thanks for all the help!!!!
bump for a good guy and to show off my new sig :evil:
Unless he changed it, 1Badazz does not have a transgo. (He's running my tranny ;) ) He has the Jerry mods set for high HP. TC stall speed will not change your highway rpm in gear.
Discussion Starter · #14 ·
Yea... to what 96GTCONV said! LOL... I'm not sure where I got the trans-go idea from... < boink, one thing to remove from signature hehehehe >.
I think you'd like it a bit looser. I picked up about a half second when I went from 2800 to 4000. My lead sled seems to do OK with a converter that loose.
1 - 15 of 15 Posts
