1 - 20 of 65 Posts
Post your "AOD" timeslips "1/8 and "1/4"
Mine is in my sig with stock converter.Car goes to shop tomorrow for tranny rebuild with 2800-3000 stall converter,manually vb,red eagle clutches and kloene steels,mech diode converstion with 2" band and dont forget supersized cooler.I hope to drop a half second in 1/4 mile time.
rsw007 said:
Car goes to shop tomorrow for tranny rebuild with 2800-3000 stall converter,manually vb. I hope to drop a half second in 1/4 mile time.
Not trying to be a smartazz, but with the stock heads, cam and intake your AOD isn't going to run a 13.4, regardless of stall speed.
86 GT 100% Stock
60ft: 2.218
1/8 et: 9.673
1/8 mph 73.11
1/4 et 15.087
1/4 mph 90.75
Car is 100% stock with air silencer and paper filter intack.
Timing was set at factory 10*. Car was run on 205/60/15 Goodyears at 22psi. Shifted car at 4700 for best times above.
Next stage on car is free mods and low cost mods.
This car will be running 13.9s with $500 budget and NO power adders! Using mostly stock takeoffs from 87-up cars. (ex: Home Ported E7 heads and intakes) Gears, SC V6 Torque convertor, Shift kit and finally sticker tires at end of mods.
Exhaust will stay 100% stock as in 86 as well as fuel system.
Ive been challenged by someone right here at Corral that says it wont happen but Im sure gonna give it a try... 13.9s here I come with "stocker" LOL
Re: Re: Post your aod timeslips "1/8 and "1/4"
POP! there goes my bubble. maybe i will get lucky with a tail wind and get a 13.499999. not many full wieght gt's like mine are capable of 13.9's with stock heads,intake and cam either so the car runs unuasually strong already. But i appreciate your honest opinion, and i will post times when i get it back.I will be happy with a .30 drop in time. thanks Scott
consistent 14.4 second quater mile with 2.73 r&p.
Mods: none, timing at 13deg btdc.
race weight 3,700lbs
with mods in my sig
60' 1.741
330' 5.230
1/8 8.207
MPH 82.59
1000 10.803
1/4 13.012
MPH 102.13
vortech sc trim, and trick flow intake with 75mm thorttle body, and steeda #18 cam coming soon
Hoping for elevens
Re: with mods in my sig
Coilz347 said:
60' 1.741
330' 5.230
1/8 8.207
MPH 82.59
1000 10.803
1/4 13.012
MPH 102.13
Hoping for elevens
Coilz347 is those times with stock heads,intake and cam"'aka stocklong block"?how about your tranny?most mild bolt on aod's run 13.8-15.2 , your making us look bad.
I would imagine that an AOD car would be say a half second behind where my car is right now with the same mods. I would imagine that you can drop near a half second with the proper convertor and gears in an AOD car with no problems.
See Sig.
Nik
14.02 @ 98.7
I have 3.55's, Full exhaust, Bumped timing, and a K&N. All of that along with a 100% stock 225,000 mile long block and 100% stock AOD.
Scott
Yes everything is stock, i havent even had the valve covers off it yet, but that run was made with a set of mickey thompson 26x8.5 slick
ok, i have beenlooking at you guys' times, and mine seem a bit off
my 1/4 time is 15.083 @ 92.4 mph ad my mods include,
AODE, 4.10 gears, shift kit, i think, under drive pullies, off road h pipe, flowmasters, k&n filter
Craig
Craig
well let's see.. you have a heavier car than the fox body, the 5.0's in SN-95 cars (I have heard) isn't enough motor to get that heavy of a car moving very well (but the 4.10s should have helped that out a little)... and add on top of that an even heavier AODE tranny. You also didn't say anything about larger mass-air meter of throttlebody.. that might be a big bottle neck on your car. You also didn't say anything about what kind of timing you are running.. and if you are spinning at all (you might need some drag radials or slicks) A converter will definately liven that thing up too!!!
when i went to the track, i had stock TB, and maf, since then, i still have my TB, 65 mm, and i also added a 75mm maf, i am running stock 10 degrees. im about to install an F cam and a converter.
Craig
aod times
See sig...ran out of powerband in the quarter, but ran [email protected] only time I've tried, pump gas.
AOD
87 gt AOD-
Stock with air silencer and 2.73 gears -1/4mile - 15.05 @ 93mph
Added 3.73,Mas Air, 75 shot-1/4 mile - 13.90 @102.5mph
Added Heads,Intake,100 shot (still stock cam) 1/8 mile - 8.500 @ 89.3 mph with a FULL tank of Gas to keep back end planted on the track. All runs were 2.17 - 2.2 60 ft times. All runs made on 245 falken street tires.:lol:
With a Good verter,slicks,launching on N2O she will be a 7.90 car.
Uhhh...
with mods in my sig
60' 1.741
330' 5.230
1/8 8.207
MPH 82.59
1000 10.803
1/4 13.012
MPH 102.13
Hoping for elevens
__________________
89 coupe, 3.55 gears, cold air, 76mm C&L meter, 95 gt suspension, 99 35th aniverserie wheels, off road h pipe,
best time to date [email protected]
Did I miss something in your mods? A 3.55 geared automatic, 76mm C&L, and an off-road h-pipe got you 13-flat @ 102 mph?? Is it just me, or does that sound incredible? How much does your car weigh? Thanks. Thomas, the Doubter... :)
the car weighs roughly 3300lbs with me in it, and the car has a t5 in it, i was launching at 5000rpm, and powershifting
I figured your car must have been gutted...
My mistake on the T5 - the original poster wanted AOD timeslips. Even so - the Corral HP estimator shows you're making 282 hp?? - with a stock 5.0 and only a 76mm C&L meter and an off-road H-pipe? I can certainly see cutting the 1.7x 60ft with slicks, but the 102.41 mph is just ???.
You know - there are 2 cars on the timeslip - you sure you're reading the correct side? :) Peace - Mark
1 - 20 of 65 Posts
