1997 Mustang GT
I have a new set of SVO heads and was going to send them to Fox Lake to have them stage 2 ported. When porting the heads is a valve job necessary afterwards?
heads
A valvejob is when they regrind the valve seats and the valves faces ,svo heads stage 2 ported thoe would be sweet.
What purpose does regrinding the valve seat and valve faces serve? Wouldn't you need larger valves then? Also...and I appologize for my ignorance..what is a 3 angle valve job/5 angle valve job?
Thanks for all the help...and sorry JACarreira for stealing your post.
Sorry for the thread intrusion but here is a link for AikiRonin: http://www.automotiverebuilder.com/ar/ar119854.htm
JACarreira, I would think that is the heads are new with the valves same valves installed, it should not need a valve job again unless the FRPP one is crappy.
I'm sure Ron @ Fox-Lake will steer you in the right direction if you ask him :)
