It took me and a friend about 6 hours total to polish all of the calpiers.... Took 2 hours for the first one and 30min. for the last one... We kinda got the hang of it after the second one...
Not for the tech... Just wandering how many brake stands can you do before the brakes start getting low, prolly like 15 seconds a piece?? Also, does it hurt the rotor when you do brake stands? Will i need any special tools to replace the pads.. I heard the Hawk brakes are pretty good...
They dont seem to "bright" for a polish job. The rear is a lot more work than the aluminum fronts. Try getting some Mothers or Eagle1 polish and getting some elbow grease involve there to make them "bright". After that, clean them and clear coat them or you will be polishing them about once a month.
Any rear caliper with a built in Ebrake will require you to turn the piston as you push it in. This defeats the self adjusting clutches in the caliper.
You need a tool and method like this:
