Does anyone know if the 4.6 police cruiser engine is same as the mustang, truck or what. and what the H/P is on them.
Yes, it's pretty much the same. The HP varies by year. The 04 PI's are up to 250 hp, they range from 215-235 depending on model year.
The 04 Police Interceptor is rated at 239 HP/287 ft-lbs. 99-04 GT's are rated at 260 HP/302 ft-lbs. The upper intake (aka "upper plenum") is of a completely different design as well. The discrepancy in power, however; is related to the Vic's inferior exhaust as well as a completely different PCM calibration. Heads, block, pistons, crank, and rods are the same though. So in other words, if you have a line on one, get it. It will be cheaper than an engine out of a GT.
Discussion Starter · #4 ·
The reason I was asking was I bought 2 of them complete intake to oil pan, I'm was'nt sure of internal's & such. both are suposed to be good, just high mile's
