What type of plug is used on World Products Aluminum Windsor Seniors?
There are stock autolite 25's in there now, but that doesn't neccessarily mean they are the right ones, I bought the car used. I have a blower so if that is correct to use stock plugs I will drop it down to a 24.
I have seen a few guys with these heads on here so I figured you'd all know.
I was able to cross that AC Delco plug 43TS on that info list to a stock 89 5.0 spark plug, which would be the Autolite 25's that came in the car. I will throw Autolite 24's in there to be a heat range colder. I called world products and they weren't much help. Should be ok with what I have. Thanks.
