MY CAR SAT FOR ABOUT 7-8 MONTHS WITH A BLOWN HEAD GASKET.WELL I JUST GOT IT ALL BACK TOGETHER AND WHEN I WENT TO START IT THERE'S NO SOUND OF FUEL IGNITING. EVERYTHING SOUNDS RIGHT(STARTER, FUEL PUMP), BUT THERE IS NO SOUND OF IT TRYING TO SPARK THE FUEL. I CHECKED TO MAKE SURE I WAS GETTING SPARK AND I WAS. I CHECKED THE INJECTOR GROUND AND IT S GOOD. I KNOW THE FUEL PUMP IS WORKING. ANY SUGGUESTIONS WOULD BE VERY APPRECIATED. EVEN A SUGGUESTION OF WHERE TO GO FROM HERE? SHOULD I DROP THE FUEL TANK AND PUT ALL NEW GAS IN IT? DAMN I LOVE FORDS.... THANKS
Old gas causes all kinds of problems - although, usually it will start - just runs like crap. Before I swapped gas I'd go back and check cam timing, ignition timing, firing order on dist. wires, be sure you have the fuel lines hooked up correctly - if you mis-match them on the barbed fittings down by the smog pump, the car will not start. If you do decide new gas is in order - I wouldn't drop the tank - I'd siphon or use a hand pump to remove it; pull a fuel line and jump the relay to use the pump to empty it -- anything but pulling the tank. If you get most of it out, and refill it with fresh - pull the fuel line and let jumper the relay to let the pump fill the lines with new gas before you try to fire it.
could it be?
could it be that since3 it sat so long the lifters arent pumping up and not letting the valves open? thanks for the help thunderrod
