Hey I have a 308 with afr 185s, track heat intake, c&l 76mm, 75mm Accufab tbody, Long Tubes and all forged internals and 30 lb injectors. The big question is where should I set my fuel pressure at? ProM says 38-42 and the ecu will compensate on all injectors up to 42. I would like to hear from people with knowledge on this subject as it is crucial, thanks to everyone who can assist and also to the Corral!!!:confused:
i would love some tips also
Best way to tell is dyno it. If its too rich or lean, adjust, make another pass. See where it goes, adjust a little, run more time. Probably worth the $60-$75 to do it
