Taking off my smogpump right now got a new belt but cant undo the tension from the tensioner. How do you relieve the tension to slide the belt off.
Put a ratchet on the part of the tensioner that's pressing on the belt, then by moving it counter clockwise it will pull up on the tensioner relieving the stress on the belt to remove it. You might have to use a breaker bar is you're weak like me.
