I have a 99 cobra and My friend is replacing all the pullies to 8 rib. I used most the lightning pullies and I had to space out the idler pulley> and the blower bracket. I have done searches here before and many people said that you didnt have to space any pullies :confused:
I think that most of the write ups that I found were for 96-98cobras and not 99's. Im not sure if theyre the same?
I shimmed out my blower bracket> but I am afraid that the bolts are not biting enough into the block> only about 1/4" into the block> did you replace your bolts to make sure they will have enough bite??????????? I am running the Vortech S trim.
Thanks for any help!
Discussion Starter · #4 ·
thanks for the bump> I ended up finding some new bolts that are longer> by spacing out my blower bracket I am able to change the belt> without taking the blower off or loosening it> which is a big plus for me.
