1 - 11 of 11 Posts
Hello all,
I'm almost done doing my 4v swap but I ran into issues with my vacuum lines. I was wondering if anyone could e-mail me close-up pictures of their engine bay so I could try and figure this out. You can e-mail me at [email protected]. Or post it on this thread.
Thank you,
RE:
jslagel said:
There aren't too many vacuum lines on the 4V engine.
Which lines are giving you trouble?
Basicly the one from the fpr, throttle body and the device next to the egr *not sure what it's called*. There is also a wire/hose coming from the firewall on the passenger side that I'm not sure where it connects.
Oh, almost forgot that I don't have the original vaccum lines for a 97 cobra. I do have the lines from a 98 Mark VIII so I'll have make my own.
Thank you!
I'll let someone else get you some pics since it would be a bit of an inconvenience. That being said however, if no one gets this for you, just PM me and I'll get this over the weekend (this is a 96-98 4V, right?)
RE:
Thank you Chris, and yes it's a 96-98 4v.
TTT
This is all I could find. I hope this helps. Just feel free to let me know if ou needed something else. I don't hagve my camera with me and had to look through some old stuff from an engine swap a while back.
I labled a couple things on the pic to help.
CHris
http://www.micro-sonics.com/winring1.jpg
CHris
Thank you Chris!!
That pic helps alot, I'm going to have to fab something up for that connector through. If you happen to run across anymore pls post them.
Thank you :salute:
this is all i have sorry,
mabey i can take some more tomorrow if you need them!
US Air Force Active Duty
I don't know if it helps, but here is the vacuum diagram from the Ford Service CD.
Thanks alot!! Every bit helps.
1 - 11 of 11 Posts
