That sensor is your EGR purge solenoid. As for the junkyard intake you picked up, I have no idea why there would be two hoses upfront there unless it was from a non-mustang application I’m unfamiliar with. On the 96 you’ll have two coolant temperature sensors one for the gauge and one for the computer. They can go in place of each small hose on either side of the junkyard intake. Be sure to use plenty of RTV sealant around the water jacket because of the gasket mismatch.
