I'm thinking about replacing my stock ignition coil on the 302 V8 (2-bbl 2150, Duraspark). I don't think it has been replaced for the past 5+ years and before that I'm not sure it was replaced either. My best guess is that it hasn't been replaced for at least 8 years.
I changed everything else: plugs, wires, cap, rotor, etc...
Which is a good replacement/upgrade?
Jacobs?
What about an ignition kit? Do they work as advertised? Something like a Jacobs Mileage Master Ultra Team? or MSD?
I'm trying to get better gas mileage and possibly more low-end power (idle to 3000 RPM).
I found some specs:
MSD-8205, for Duraspark ignitions
Max of 45,000V
Primary resistance 0.7 ohms
Secondary resistance: 10,500 ohms
Turns ratio: 100:1
Jacobs 380672F (Ford duraspark)
Primary resistance: 0.6 ohms
Secondary resistance: 8500 ohms
Turns ratio: 90:1
Max escape voltage of 40,000V
