1 - 12 of 12 Posts
Brand new in the box.....has to go...best offer!:beer: Performance Automatic Announces Ford 5R55 Deep Pan
Performance Automatic of Gaithersburg Maryland proudly announces the release of their new deep aluminum pan for the Ford 5R55 N, S and W series transmissions. This transmission is the primary 5-speed rear wheel drive automatic for many vehicle lines including the Ford Explorer, Ranger, Lincoln LS and the 2005 and up Mustang.
Cast from high strength aluminum alloy and machined for a drain plug this pan increases fluid capacity by 4 quarts on the 5R55. This pan will also allow the use of Performance Automatic’s new matching transmission filler tube and dipstick. This eliminates the need for a special tool and the messy and often incorrect factory fill procedure. Fluid level checks and refills can now be made under the hood, not under the car!
Maintenance and fluid changes made easy with the Performance Automatic deep aluminum pan and filler tube kit part number PA27455KT. (Pan only PA27455)
e-mail me at [email protected] or call weekdays at 301-931-3673 or on my cell # 443-510-5493
I know the thread is old...but do you still have this?
RH
1 - 12 of 12 Posts
