I have a Proform electric fan looks like the exact same as Black Magic. Directions say attach positive terminal to a low amp 12 volt source such as fuse box.
optional connection- attach positive terminal to an ignition source to stop fan when after car is turned off.
what ignition source can i wire it to? If i hook it up to an ignition source then I wont have to hook i up tothe fuse box, correct?
Also, if I dont have AC then i dont have to worry about the AC connection, rght?
thanks, Mark
If you use any of the hvac controls I would consider doing the ac connection just to be safe. With the ignitoin switch source, No matter what run at least one fuse in the line, weither it be from the fuse box or another, run a fuse, or two. as for the source, I belive you could probly use the starter selinoid... but are you going to use a tempeture regulator or just switch used?
