i have eibach sportlines and tokico 5-ways. what setting do you guys have these shocks/struts set at, and why? shouldnt the rears be set softer than the fronts? thanks...
Ditto.danmatar said:mine are set at "4" all around. To be honest, I really haven't spent a great deal of time playing with them. And I haven't had a chance to go auto-xing lately. I picked setting 4 because the premium struts/shocks are equivalent to a "3" setting, so I just went a notch up for now.
I have the Supersports also, and mine are set to 5f/4r. With a typical Mustang set up, you want the front one notch stiffer than the rear. Also note that a softer shock setting will not necessarily mean a better ride. If you set them too soft, they won't be able to control the springs and the ride will be too bouncy. Unless you are drag racing, they should never be set to 1, front OR rear. I'm not sure what the sportline rates are, but try 4f/3r and 5f/4r and see which one you like better.KenB said:It depends on what springs you are using. I'm using H&R supersports which are about 750 in the front and 280 in the back. With these rates, I have found 5 in the front and 4 in the back to be perfect. What are the spring rates on the sportlines?
Ken
Do you mind if I ask what settings would you recommend for my setup?J98GT said:
I'm an engineer for Tokico BTW. I do shock tuning and design on some our OEM applications.
I usually use 5 at the right rear and 1 on all the others.And one more - what settings do you guys use at the strip?
